disable bgp
disable bgp
Description
Disables BGP.
Syntax Description
Default
Disabled.
Usage Guidelines
Use this command to disable BGP on the router.
The following command disables BGP:
disable bgp
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
